2009 – Expanding the Terror Series
Ade Emsley – Technical Director
Tiny Terror Hard Wired Edition
The Hard Wired Edition amplifier was completely point to point, hand wired and made in the UK. It was the standard Tiny Terror circuit, but featured carbon comp resistors, ‘mustard’ capacitors and high specification transformers. This gave the Hard Wired Edition a wider frequency response. The controls were the same as on the original, with the 7 watts or 15 watts output option, but the Hard Wired Edition weighed slightly less.
Dual Terror
Dual Terror is an amp for stage and studio. It features two channels – the ‘Fat Channel’ and the ‘Tiny Terror Channel’. The Fat Channel is voiced warmer and has more bottom end, gain and crunch. The Tiny Terror Channel features the classic Tiny Terror voicing and tone. There is a choice of four outputs through each channel: 7 watts on two tubes; 15 watts on two tubes; 15 watts on four tubes or 30 watts on four tubes. It features a high specification transformer.
Dual Terror
Terror Bass 500 & 1000
The Terror Bass was slightly smaller than the famed Orange Tiny Terror, weighing around 5 kilograms. Terror Bass was available as a 500 watt or 1000 watt hybrid amplifier with a Class D solid state power section and the AD200B twin valve 12AX7 preamp section. The jack plug sockets on the side of the Terror Bass amplifier were an FX loop.
Terror Bass 500
