With an all valve front end, the Terror Bass is a 500W hybrid bass amp with a valve preamp and solid-state power amp, making it closer to the sound of our flagship AD200 than ever before, with a front panel that remains the same layout to the original Terror Bass but with an added clean switch, giving more headroom and smoother, clean sounds.
From clean pop sounds through to gritty rock tones the Terror Bass can do it all. A pad switch on the front for active basses takes 6dB off the input sensitivity. The effects loop is valve on the send and solid-state on the return. The Terror bass is a Class D amp with 500 watts of power into 4 Ohms and 250 Watts into 8 Ohms, the limiter switch on the back prevents the output stage from being pushed too hard into 4 ohms.
We met bass wizard Adrian Bartol in Madrid and captured the tones you hear in this video, using his Moollon bass and new Terror Bass and OBC112 miking the room, to bring you all the expressiveness and versatility of this ultra-portable professional rig, from Motown_esque groove to pop, from punk to contemporary rock, the Terror Bass covers every base and the OBC112 can follow you from the studio to the gig.
YOU KEPT ASKING FOR IT…
The all-new, re-designed Terror Bass has arrived and it sounds better than ever.
