Product Launch: The Baby Range
Orange Announces Three New Portable and Powerful Baby Guitar Amps
Like a proud parent, Orange Amplification is delighted to announce the arrival of its new Babies: the newly analogue designed Dual Baby, Tour Baby and Gain Baby guitar amps. Each lightweight, studio grade 100W, twin channel, Class A/B, solid state amp weighs only 3kg and is compact, reliable and tour ready. Watch the launch video here.
The 2-channel, Tour Baby guitar amp is incredibly versatile in a variety of playing situations. The onboard studio grade VCA compressor of Tour Baby’s refined clean channel, offers pristine clean tones with active or passive pickups. It provides a consistent dynamic range and low noise in extreme settings without the need for separate pedals. It includes precise bass and treble EQ controls.
The naturally voiced dirty channel of this tone machine allows players to easily get that sought after ‘point of breakup’ sound . A custom voiced presence control and powerful 3-band EQ control means the Tour Baby’s tone can be shaped to cut-through the mix. Add to that a footswitchable volume control, that provides a stage-friendly volume boost option for live applications. Watch the Tour Baby video here.
The Gain Baby clean channel is the same as that of the Tour Baby with its integrated VCA Compressor to alleviate the need for an additional stomp box and incorporates bass and treble EQ controls to dial in a desired frequency. The compressor provides smooth, transparent compression for dynamic control without compromising tone.
Four distinct stages are available on the high gain channel allowing players to dial in their preferred level of crunch and saturation. Like the Dual Baby, Gain Baby’s Tight Switch operates as a bright switch, boosting the upper mid at lower gain levels, to give shredding solos a little something extra. Volume control is footswitchable, the buffered FX allows effects from pedals to be patched in and the onboard 3-band EQ allows tone to be tweaked even further.
With multiple output options such as a balanced XLR output with no Cab Sim, as well as dual speaker outputs, the Gain Baby is equally comfortable on stage or in the studio. Watch the Gain Baby video here.
The Dual Baby is a powerhouse in a pint-sized package. It’s simple A and B channel design offers duelling tones and alternating rhythm opportunities. Channel A mimics the rich responsive tones of the Orange flagship Rockerverb amps in a reliable solid-state design. From clean to classic crunch to full-on saturation, there is no shortage of Orange mojo. The brand-new Tubby Switch, which boosts the bottom end early in the signal path, offers a much ‘rounder’ tone when playing clean or when searching for just the right ‘dirty-clean’ sound.
Channel B allows players to dial in the desired level of grit, with ample saturation and a valve-like high-gain tone, unheard of in any other solid-state unit. The ‘bright boost’ of the Tight Switch gives the amp spring and bounce and raises the top end at lower gain levels for players who want to tighten up, shred and play blistering solos with plenty of cut. The 3-band sweepable EQ presence control allows frequencies to be tweaked, shimmer added and mids that sit perfectly in the mix to be dialled in. Watch the Dual Baby video here.
Pack or rack any of the three Baby amps with included gig bag or an available rack ear kit. Each Baby is a mighty unit that delivers100-Watts into 8 ohms or 70-Watts into 16 ohms, to power any full-sized guitar amp with ease!
