Adrian Emsley, Technical Director:
“The circuit of the Pics Only is markedly different from that of the first Orange amplifiers. Those early Orange amps like the OR200 had the volume in front of the EQ circuitry, whereas the Pics Only had the Baxandall EQ first, then the Gain, and then the phase inverter. What’s more, the DC-coupled ‘concertina’ phase inverter used in the first Orange amps was changed to a capacitor-coupled version in the Pics Only. This capacitor-coupled type of phase inverter drives the output valves harder and this creates a more overdriven and crunchy sound. In this way, the Pics Only was the start of the new sound that everybody associates with Orange.”
Mick Dines:
“The ‘Graphic Valve Amplifier’ was designed in-house by John James in 1971 and manufactured during the period 1972-75. It was soon nicknamed the ‘Pics Only’, a reference to the front panel graphics which were unique at that time. Earlier versions had Woden or Drake drop-through transformers, later ones had Parmeko. A four channel PA version was introduced [pictured left top]. Some Pics Only’s were made and sold right up until 1975 – especially Slave 120 Graphics [pictured left below] – in order to use up stock and components. There was often this kind of overlap when a new Orange series was introduced.
Early Graphic Pics Only’s soon became known as Plexis because they had a plastic reverse-printed Perspex panel secured on an orange steel backplate fixed to the chassis. The amplifier was secured into the cabinet with four front panel fixing bolts with plastic seating washers. The panels on later Pics Only amps were not plastic, but silk-screen printed metal plates with no visible bolts.
In hindsight, the graphic icons were perhaps a bit too big and prominent on the Plexi. So in 1973, we went back to the drawing board and redesigned the front panel, as well as making other electronic modifications. The result was the Graphic 120 ‘Pics & Text’ amplifier. The Pics Only was the start of the new sound that everybody associates with Orange and it has influenced the design and sound of Orange amps ever since.”
hi, since last week i’m the proud owner of a ‘plexi’ OR120 amp but the plexi panel is in bad shape. I was wondering if you happen to have some of them left on a shelve somewhere? just a long shot….
Also the backpanel is missing including it’s typical Orange aluminium modelnr. plate. Are those by any chance available? any help is welcome. much appreciated. regards Agaath
